  3. Wanted Ads
  4. Ecu
Ecu
10 Posts 5 Posters 1.0k Views
  • krzydrftr93K Offline
    krzydrftr93
    Anyone have a JDM P08 ECU???
    Matt
    92 Civic HB
    JDM d15b w/14b@8psi
      honda-tech.com
        Why do you need a P08 and nothing else?
          krzydrftr93
          Well from my research(yes I did some research) Vtec kicks in later on the p28 i got from phearable and so I will loose power. So therefore I want a P08
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            I'd suggest a chipped P28 with the P08 BIN file burned onto a chip:icon_study: From what iv heard P08's are hard to find.
              for the millionth time, Honda sets vtec at a certain point for a certain reason, messing with your vtec point with stock cams/stock motor is an idiot move.
                krzydrftr93
                Joel the P08 goes with the damn motor So therefore I wouldnt be fucking with the vtec point if i used a virgin P08 now would i.
                Matt
                92 Civic HB
                JDM d15b w/14b@8psi
                  actually, a bit lower vtec can actually create a smoother dyno curve...learned that from somebody on here that knows a bit more about hondas than me and you joel...combined
                    ok joel calm down..... just do as bumpinjcc said easiest plan...
                      damn straight son.:icon_monkey:
