  4. B Series
B Series
28 Posts 10 Posters 2.0k Views
  • 94_dsm_nt9 Offline
    94_dsm_nt9 Offline
    94_dsm_nt
    I am getting myself a 94 Integra with a B18B1, and the timing belt broke. I was wondering if it would have bent the valves or not, and if so will any B-Series head work on it?
    1987 Mustang GT
    New Toy: 1976 F-100 4x4, 10 inches of lift, 390 with Edelbrock Performer intake, Holley double pumper, 4:50 gears, front and rear lockers, 38x15x15 Super Swampers. :icon_thumright: :D
      well the valve are most likly bent. you can use any integra ls head from 90-01
      heads:
      • 90-93 b18a
      • 94+ b18b
      and if you want an upgrade you can use a dohc vtec head and do a ls/vtec. this would require you to get a new ecu, oil lines(to provide oilto the head), steped dowel pins, a 1/8th npt tap, and some wiring.
      heads:
      89+ jdm b16 a
      92-93 gsr b17a
      93-95 del sol b16
      94-01 gsr b18c1
      94+ jdm gsr b18c
      96+ itr b18c (usdm b18c5)
      and the list goes on.....
      • itRfanI Offline
        itRfanI Offline
        itRfan
        I personally would do the ls/vtec swap. But if thats not in your budget at this time then just find a stock b18a-b18b head till you can.
        -weshole
          94_dsm_nt9 Offline
          94_dsm_nt
          Yeah, the LS V-TECH swap isn't in my budget, until i go back to school for auto technology. I cant immagine a head is too cheap right now either.
          1987 Mustang GT
            what about removing and getting your head checked? that would be cheaper, if you bent on valve get that fixed...
            I know more then likely something is possibly damaged. I personally would rather spend the $20 or what ever to have a machine shop check out the head and make sure it is unusable before I drop $200 or what ever on a new head, when the otherone was fine.
              I have a b20 head sitting around i'd like to sell, I hear they're the same as a B18 head.
                you can pick up ls heads all day for less then $50.... so it isn't to bad to just replace the whole thing
                  ahhh yes, the rare phone powered swap. Seen in done on pimp my ride.
                    94_dsm_nt9 Offline
                    94_dsm_nt
                    yeah i was tired and had my phone in front of me:rolleyes:
                    1987 Mustang GT
                      94_dsm_nt9 Offline
                      94_dsm_nt
                      let me know how much you want. how long would it take me to replace a head?
                      1987 Mustang GT
                        it would take a few hours...
                          I have a bare LS head that is all cleaned up with no valves or anything, so if you wanted to throw some valves in there, and use the rest from your head you could.
                            I have actually seen timing belts on LS motors break and nothing happen to the valves as long as the motor wasn't very high in the rev range. I'd throw a belt on it first and see if it runs, then go from there.
                              94_dsm_nt9 Offline
                              94_dsm_nt
                              yeah i guess the kid bought a timing belt for it. even if I have to replace the head, I can't complain cause I'm basically getting the car for free.:icon_thumright:
                              1987 Mustang GT
                                You could just sell it to me, or trade me for one of my cars that runs......
                                  94_dsm_nt9 Offline
                                  94_dsm_nt
                                  well it depends on what you have to trade, otherwise I've been looking for a integra for a while.
                                  1987 Mustang GT
                                    Pm'd
                                      If you need a head, mine should be complete, just shoot me an offer.
                                        94_dsm_nt9 Offline
                                        94_dsm_nt
                                        We'll see if the car will run with the head thats on it now otherwise if it doesn't then I will be looking for one.
                                        1987 Mustang GT
                                          94_dsm_nt9 Offline
                                          94_dsm_nt
                                          will i have to put in a water pump and new belt tensioner when i replace the timing belt?
                                          1987 Mustang GT
