  4. DIY Mods
  5. y8 in a rex
y8 in a rex
Scheduled Pinned Locked Moved DIY Mods
21 Posts 9 Posters 10.5k Views
  • CRX_CivicC Offline
    CRX_CivicC Offline
    CRX_Civic
    ? For the CRX people. how hard is it to swap a y8 into a 89 crx? it should just drop in bolt up and go,right, just change ecu? do the motor mounts match, harness, everythin?
      I'm not much on D-eries codes, but isnt a y8 OBD2....
        For sure you'd need a jumper harness, wire in vtec, 4 wire o2 sensor, since your sig says its a dx and if that's the crx ur wanting to put it in then you'd have to do a MPFI swap as well....
          A motor doesnt know what Diagnostics system it is.
          You will need the following if you want to run OBD1(easiest):
          -cable transmission(89-91 Si trannies are the best cable D trans').
          (you could use DX or HF trans... but they make your car way slower)
          -DPFI-MPFI wiring(http://www.angelfire.com/d20/hcivic88/dx-siwiring.html)
          -Vtec wiring(http://hondaswap.com/general-tech-articles/how-wire-vtec-40811)
          -p28 ecu(92-95 civic EX)
          -obd1 Vtec distributor(92-95 civic)
          -injectors(depending on which you use you may need to wire in a resistor box)
          I would suggest looking for a full a6 swap(89-91 si) or just doing an MPFI swap on your d15. A lot less work and almost as much HP gain. you could even put the d15 head on the y8 block if you want thats extra displacement...
            If you just need a new motor, you can swap out the long block and keep your IM, ecu, dizzy (you would need to swap housings), alternator, and all. Then it will run and drive without vtec and all. To have vtec then, you would need to swap everything like Wannabe said. Ordering a full conversion harness would be the easiest cuz otherwise it is a lot of wiring to figure out.
              If you're gonna spend the money get a full OBD 0 B18 swap, mounts, and linkage...cost bout a grand...lot more power than messing with the D series...Trust me I had one in my CRX and it ripped very good.
              • gsrEKG Offline
                gsrEKG Offline
                gsrEK
                pretty sure i never saw u do any rippers in ur ls swapped crx???? just buy a obd0 b16 and b done but as u can tell brandon knows everything
                2009 Yamaha Zuma 125, gas HOG
                2008 Honda Fit daily
                A s2k
                1991 Honda civic DX Mint SOLD
                1988 Mitsubishi Mighty max
                > BlackEJ8;233529 wrote:
                  you know you are tired when y8 looks like v8
                    bubba;190911 wrote:
                    ...lot more power than messing with the D series....
                    D > bubba
                    have some respect
                      I have respect for yours...but unless u boost the D, the majority of them are turds...
                        lol, I bet kevins z6 hatch wouldve raped your L crx. dude theres like a 10 hp difference. all old LS's are beat anyways. his y8 would rip just as good as a tired LS swap, and a lot less time/money
                          no parker, a V8 swap is not always the answer.
                            awwww..... dammit
                              Yea, cuz all motor b-series are so fast........yea right.
                              • GhettoFabulousCRXG Offline
                                GhettoFabulousCRX
                                since when were hondas fast period?
                                1993 Nissan 300ZX- Twin Turbo
                                1995 civic CX
                                2006 Honda CRF50
                                1987 Yamaha Ysr-50
                                1995 Acura Integra sold
                                7 EF civic or crxs sold
                                  All motor hondas in general arent usually fast, but at least u can get 300hp outa b and k series with all motor...havent seen any d's that came close to that....granted i'd never do that cuz it's a waste of money, personally boosted b's are the way to go
                                    CRX_CivicC Offline
                                    CRX_Civic
                                    The crx is my winter beater....the y8 would be left over from my civic if i got something else , idk, ive never rode/drove in any civic other than a na d-series, so im pretty clueless. thanks for the replys.
                                      Well if it's just a winter beater I would recomend not going for a lot of power, lol. I drove my crx with a ls swap last winter, and was worthless even with snow tires. Should work if u convert the dizzy and stuff to obd1 and the car to MPFI and then use an OBD0-OBD1 jumper harness, but get one that has the wires for vtec and 4 wire O2 sensor on it....You can use your stock crx trans, or put an si one in if u want a little shorter gearing.
                                        do an MPFI swap, leave your stock motor, get an SI intake manifold, fuel rail and fuel injectors. even with the d15b2 its like a 25 hp gain...
                                          GhettoFabulousCRX
                                          weird.. my DPFI hatch was faster than my MPFI hatch that I have now. 25 hp gain? I read a dyno chart they claimed like a 12-17 hp gain wich realy isn't worth it. I'd leave your mpfi and swap the block and head if your dizzy fits on it. Your stock dizzy will fit on all 88-91 heads, I know for sure it fits on 96-00 heads and 92-95 heads that are not vtec-e
                                          1995 civic CX
                                          2006 Honda CRF50
                                          1987 Yamaha Ysr-50
