  4. Epoxy removal
Epoxy removal
15 Posts 7 Posters 997 Views
    I need to un-epoxy some magnets from an aluminum cam gear. I tried heating the crap out of the thing, hoping the epoxy would soften but no luck. I've read on the internet that acetone will soften the epoxy, has anyone tried this or any other recommendations on getting epoxy to let go?
      http://www.wmbarr.com/product.aspx?catid=72&prodid=135
      I dont know if its safe to use on aluminum
      I dont know if this particular brand is good but the aircraft paint remover should do it.
        do you the magnets need to be reused?
        Sounds like a dumb question, but i am not positive they need to be salvaged if you say you were heating them...... unless you were using a heat gun, and in my head you were using a rose bud. haha
        • vss2kV Offline
          vss2kV Offline
          vss2k
          Paint Removers such as Old Masters TM-4 would work well because they are heavy bodied almost like a paste for vertical surfaces. Make sure to wear gloves, beacause it burns. TM-4 has the ability to remove up to 15 layers at a time, so it should suffice for epoxy
          Team EMOTION
          TSCatalyst.com
          • 63vette6 Offline
            63vette6 Offline
            63vette
            Methylene Chloride is the only chemical that will touch it. It also causes more health hazards than I would be willing to deal with. I would replace the cam gear sensor Mr. Moneybags. 🙂
              kleen strip aircraft remover?
              • 63vette6 Offline
                63vette6 Offline
                63vette
                fishin... did someone say fishin? I know fishin. 🙂
                • XJHEADX Offline
                  XJHEADX Offline
                  63vette;260597 wrote:
                  Methylene Chloride is the only chemical that will touch it. It also causes more health hazards that I have to deal with.
                  That explains a lot..
                  • XJHEADX Offline
                    XJHEADX Offline
                    Try freezing it and a good whack. Use a can of freon, spray it upside down to get the liquid on it.
                      lol cuz thats legal..........
                      not that I care. lol
                      • 63vette6 Offline
                        63vette6 Offline
                        63vette
                        Unhook the freon line from your homes central air, point it an the part, have a beer, chuckle and go back inside.
                        Then use a 12lb hammer, it will pop right off........in little pieces. 🙂
                        Come on! Its magnets, freezing them and hitting them wont ruin them right?
                        • XJHEADX Offline
                          XJHEADX Offline
                          Where did he say he was re-using them?
                          • 63vette6 Offline
                            63vette6 Offline
                            63vette
                            Oh, thats different. Then just cut them off with a dremel and clean the excess off with a razor blade and some emery cloth.
                              The magnets are 1/8" diameter by 1/4" deep. The cam gears are drilled so that the magnets drop into a 1/8" hole and are flush with the surface of the gear. Then a little epoxy is poured in the hole and the magnet set in. I haven't tried to drill or machine the magnets yet, I put two in incorrectly and hate to have to start all over with a new gear. There are 13 magnets in the gear, and a new set of magnets is $80. 😕
                              • XJHEADX Offline
                                XJHEADX Offline
                                Can you drill the backside with a small bit and try to push them out?
