Flamethrowers
Does anybody know anything about laws on flamethrowers. If you get caught is just going to be an exhibition?
Reason I'm asking is I helped a friend build and install one on his Geo Metro and it turned out pretty cool so I'm thinking about doing it to my car.
Well his Geo is fuel injected but it uses a coil like any points style distributer would use so he ran a wire from the negative side of the coil to another coil that fires a spark plug in the exhaust tip (it has to be in the tip) then he welded a fuel injector (didn't actually weld the injector) into the tail pipe, put a T-fitting in the gas line (after the fuel pump), hooked it all up to two relays (have to have 2 otherwise the injector back feeds off the coil and will be open all the time) and a momentary rocker switch. But there's some technique to using it because there's not enough exygen in the exhaust to ignite the gas. If you're not moving you have to rev it up and come all the way back down to idle then it draws air into the pipe. We took it on the Interstate and hit the switch and it worked great.
It will shoot a 2-3 foot flame when you're parked.
I don't know for sure. If you did propane and wanted to do it right it would be more than 125. Unless you can find a cheap electric bottle valve. with gas you can get off cheap, all you need is a coil, old spark plug, plug wire, old injector, a couple relays, switch, and some wire.
propane is the way to go though
propane is the way to go.. its eaiser to control then trying to time the mixture of your exhaust...just push the button
is this the geo drivin around town with like taht tip that has some curve to it, my friend who also has a metro made a flame thrower kit but couldnt get any spark but when we held a lighter at the end of tip he had some that were prolly 4 feet so we tried it usuing a friends go kart racing alcohol and the flames were shittier, but it still is tight shit seeing flames from a geo, and it was the metro that has all those stickers in the back windows and its low
I happen to know of a few guys who run it on their semis..ya know the 18wheeler ones. They use it to climb hills and for shits and giggles in the smoke stacks.
