  4. finally more turbo for the diesel
44 Posts 13 Posters 3.8k Views
    Picked this up
    It is a Borg Warner S364, billet titanium compressor, 14cm/.8ar hotside..... setup for the cummins
    It is identical to the BD super B special except theirs doesn't have the Ti compressor
    supposed to support 550whp on diesel alone, and is made to be easily integrated into a compound twin setup later if desired since it has the huge gates needed for that
    Hopefully i wont be able to bury my 1600* EGT guage within a few seconds now... and be able to turn up the fuel plate more and utilize my big injectors
      thought you were putting it on today, i wanna hear it no vid you are fail
        i wanna see a vid when its done
        • M Offline
          M Offline
          MNMKIV
          look forward to the results. since i am a noob around here is there a thread about your truck?
          97 6mt sp .67 .81 A/R huge e85 fuel system in the works.
            na, the truck is just the rattle trap DD, no thread for that
            car has one, that is a turbo ls1 swapped rx7
            • M Offline
              M Offline
              MNMKIV
              ever consider a water meth injection to help with the egt's a bit?
              • SheeranS Offline
                SheeranS Offline
                Sheeran
                yeah i would water/meth for high egts.....but this will work easily...you should make a thread for the diesel
                  Dibs on the HX35?? 🙂
                  • SheeranS Offline
                    SheeranS Offline
                    Sheeran
                    also what PSI you looking to run with this and what was your pevious PSI with the HX35 previously mentioned
                      For what, your bookshelf??
                        Yup, exactly. Only ever a bookshelf.
                        • beachbum_jonB Offline
                          beachbum_jon
                          Yawn...
                          Ditch that for a s357 over a s475...unless that is you are planning on using this as a top turbo someday..:)
                          -John Adams, 1735-1826-
                            beachbum_jon
                            Yawn...
                            Unless you are planning on butting this over a s480 or something someday
                              The turbo alone should give the relief i need on the EGT's
                              Not getting carried away on this thing, I just want make around that 500whp mark and be able to use most of that power when pulling while keeping EGT's manageable..
                              may need twins to do that successfully, but this will give an idea of if that is required
                              had a 35psi gauge forever and just knew that it burried that... finally got my 60psi gauge on and it runs right at 42psi...... stock truck that vintage is at ~18psi stock
                              The stock HX35 is not doing anything good there but being a blow torch and sending drive pressure through the roof.... the new turbo is gated at 40psi..... 45-50psi should clean what fuel i have available currently
                              stock HX35s do fairly well up to about 32psi and it is down hill steeply above that
                              beachbum_jon;298596 wrote:
                              Yawn...
                              yeah, this turbo over a 400 variant
                              If this cools what i want then no need to though
                              This isn't some drag racing toy.... I DD it and pull often, and like to have a beast when i am pulling 😉
                              What i really need to happen is for the stock HG to let go so that i have motive to pull the head and have that rebuilt, ported, and o-ringed with some studs
                              If i need more fuel the next thing i would do is delivery valves....... not going to some recockulous big injectors because i like my mileage and clean burn
                              i do around that 20mpg mark on I-state at 80 and a bit better at a slower speed
                              bumping my timing, the injectors, and taller tires helped in the mileage department
                                beachbum_jon
                                i nice set of tow twins would be a s357/s475
                                  ooooo you will have to come visit my dad now! He will probably want to take a look under there!!
                                    Have to see how this spools by itslef
                                    Auto truck so once i get it spooled once i am good to go regardless
                                    Manual trucks would blow balls trying to pull with a single this size......... every shift re-spooling without the converter to help you
                                      beachbum_jon
                                      yeah mu buddy had that same turbo you just got on his vp44 truck which is a 5spd and with stock injectors, monster stage 1 pump, he could barely spool that thing, then we built his twins and he got 150's and it moves pretty good.
                                      • SheeranS Offline
                                        SheeranS Offline
                                        Sheeran
                                        good luck with it....i almost hope it doesn't do what you want cuz i want to see a twin build....lol
                                        How big is the Diesel truck scene around here i saw a Harlel Davidson eddition F-250 in diesel power a few months ago and i've seen a few nice trucks driving around (not to mention all the trucks at M-state when diesel tech classes are going on) but it doesn't seem to big
                                          True story! I drove a 2006 Dodge 3500 Cummins(long box, 4 door, dually) in a 6-speed when I moved. I hated every second of it.
