  4. car surging from 1000 to 1500 rpms
13 Posts 9 Posters 966 Views
  • 95_gsr_swap9 Offline
    95_gsr_swap
    so i have a d15z1 i put an si intake manifold with a blox 68mm throttle body. when everything was hooked up and lines were ran the it surges from 1000 rpms to 1500 rpms was wondering if this had anything to do with not having the egr valve hooked up and if so if anyone knows how to jump the wires so i can have the si intake atleast and a lil bit of balls in the car verses the 1.25inch throttle body.
    anything would help if anyone has any ideas let me know ty
    92 Honda Civic VX 1.5l vtec-e - SOLD
    86 Toyota Corolla - Project
    B18C1 Boost Project Soon To Be Done Once Home - SOLD
    92 civic coupe b18b swap
      periods are your friend
      just saying
        just saying
        What exactly does you and your sick choice of fetish have to do with this thread?
          Bigger TB does not necessarily mean more power (this would be one of those cases). You are wrecking that motor, it will never be fast, so you might as well keep the awesome gas milage.
          That being said, ill take vacuum leak for $400 Alex.
            68mm t-body on vx, LOL
            • blackcherryTSiB Offline
              blackcherryTSi
              ecu... swap with another... will solve the problem
              1995 Honda Civic
              • gsrEKG Offline
                gsrEKG Offline
                gsrEK
                Hmm really? honda guru
                2009 Yamaha Zuma 125, gas HOG
                2008 Honda Fit daily
                A s2k
                1991 Honda civic DX Mint SOLD
                1988 Mitsubishi Mighty max
                  lol sure
                  • untitledfolderU Offline
                    untitledfolder
                    Vacuum leak, bad IACV, wrong plugs on sensors. It could be multiple things. Try the easy stuff first like taking off the IACV and cleaning it with brake cleaner, check and make sure you don't have any ports that are left open and aren't supposed to be.
                    > ichibankilla;213613 wrote:
                    2000 Honda Civic CX LS/Vtec
                    http://www.clubredline.net
                      95_gsr_swap
                      its going back to stock tonight. i just wanted to get rid of the egr valve and go to a normal throttle body ,but its gonna be a pain and not worth it so thanks for the info
                        blackcherryTSi
                        DelSlow;315668 wrote:
                        lol sure
                        laugh all you want... its has to do with a burnt out piece inside. ive rode in the car, exact same thing happened with my rhd... swapped ecus and TA DA! all gone
                        1995 Honda Civic
                          95_gsr_swap
                          ok bryant if thats the case wut do i do with the vacuum lines id like to run the si manifold and throttle body so let me know if u have any ideas
                            blackcherryTSi
                            i can stop by and tinker with it any time this week if you want just hit me up
                            1995 Honda Civic
