  4. The bmw 1 series M!!!
14 Posts 7 Posters 2.3k Views
  • E Offline
    E Offline
    Eurofan
    http://www.youtube.com/watch?v=1spzeR-giq4&feature=player_embedded
    Ohhhh my goodness.
    Pure enthusiast car, as intended. It is only available in manual transmission and was produced souly with us in mind...
    • drift86D Offline
      drift86D Offline
      drift86
      Ok you win today. I like that car.
      AE86 project: sold
      93 r33 gts25t new project
      00 impreza obs
        Finally, i've been hoping for this for a while... I wonder if it'll be the "new" e30..
        • beachbum_jonB Offline
          beachbum_jon
          Love it! Cant wait to test drive one!
          Euro, any specs been released yet? I looked at m-power.com and bmwusa.com but no specs that I could find.
          -John Adams, 1735-1826-
          • E Offline
            E Offline
            Eurofan
            Ill tell you later tonight 😉 official release tonight.
            Its n54 equip... TT 3.0 liter inline 6 pushing 360ish hp/tq... 0-60 will probably be in that mid 4's range with a flat 13 second 1/4 mile. Thats not really what they are made for though, this car is supposed to be the most pure BMW since the original M3. The car/driver connection will be unparalleled. Heres the best part... priced in the mid 40's.
            This car will be epic. Now, lets hope the masses like it and they produce more like it.
            EDIT::::::::
            Here it is guys, the official stuff. WOW!!!
            1M TO 135I COMPARISON
            0 - 100 kph 4.9 s 5.3 s
            0 - 200 kph 17.3 s
            Top Speed 250 kph 250 kph
            Power/Weight Ratio 4.4 kg/bhp 4.75 kg/bhp
            Power/Displacement Ratio 114.1 bhp/l 102.7 bhp/l
            Engine
            Type/valves in-line 6 / 4 in-line 6 / 4
            Engine Technology M Twin Power Turbo BMW Twin Turbo
            Capacity (cc) 2979 2979
            Stroke / Bore 89.6 / 84.0 89.6 / 84.0
            Compression Ratio 10.2 10.2
            Output (kw/PS/bhp) 250 / 340 / 335 225 / 306 / 300
            @ 5900 rpm 5800 rpm
            Torque (Nm / lb-ft) 450 (+50 overboost) / 332 (+37 overboost) 400 / 295
            @ 1500 - 4500 1200 - 5000
            Gearbox
            Transmission Type 6-speed manual 6-speed manual
            Gear ratio I / II / III 4.110 / 2.315 / 1.542 4.110 /2.315 / 1.542
            Gear ratio IV / V / VI 1.179 / 1 / 0.846 1.179 / 1 / 0.846
            Body
            doors / seats 2 / 4 2 / 4
            Length (mm) 4380 4360
            Width (mm) 1803 1748
            Height (mm) 1420 1408
            Wheelbase (mm) 2660 2660
            Track Width front (mm) 1541 1470
            Track Width rear (mm) 1541 1497
            Turning Circle 11.5 m 10.7 m
            Fuel Tank Capacity 53 l 53 l
            Cooling System incl.heating 10.4 l 8.2 l
            Engine Oil 6.5 l 6.5 l
            Unladen Weight DIN / EU 1495 kg / 1570 kg 1455 kg / 1530 kg
            Weight US 3296 lbs 3373 lbs
            Trunk Capacity 370 l 370 l
            Driving Dynamics / Safety
            Suspension, Front Aluminium double pivot spring-strut front axle with trailing link; small positive kingpin offset: lateral force compensation; brake dive reduction Double-joint tiebar spring strut axle, aluminium
            Suspension, Rear Five-link axle in lightweight construction with drive-off and brake dive compensation Five-arm axle, lightweight steel
            Brake, Front Single piston floating caliper compound disc brakes Six-piston fixed-calliper disc brakes
            Diameter (mm) 360 x 30, vented and perforated 338 x 26, vented
            Brake, Rear Single piston floating caliper compound disc brakes Two-piston fixed-calliper disc brakes
            Diameter (mm) 350 x 24, vented and perforated 324 x 22, vented
            Driving Stability Systems Standard: DSC incl. ABS and M Dynamic Mode (MDM), Cornering Brake Control CBC, brake assistant DBC, dry brake function, fading compensation, drive-off assistant, variable M differential lock Standard: DSC incl ABS and DTC (Dynamic Traction Control), CBC Cornering Brake Control, DBC Dynamic Brake Control, Dry Braking, Fading Compensation, Start-Off Assistant, M sports suspension and electronic locking function on the rear axle differential
            Safety Features Standard: airbags for driver and front passenger, side airbags for driver and front passenger, head airbags for the front and rear seats, crash-active headrests at front, three-point automatic seat belts for all seats, at front with belt tensioner, belt force limiter and belt stopper, crash sensors, tyre damage display Standard: airbags for driver and front passenger (two-stage), side airbags for driver and front passenger, head airbags front and rear, three-point inertia-reel seat belts on all seats, with belt retainer, belt latch tensioner and belt force limiter at the front, crash sensors, Tyre Defect Indicator
            Steering Rack-and-pinion with hydraulic support and Servotronic function Hydraulic steering
            Steering Transmission 12.5 : 1 16.0 : 1
            Tires Front 245/35 R19 93Y XL 215/40 R18 85Y RSC
            Tires Rear 265/35 R19 98Y XL 245/35 R18 88Y RSC
            Wheels Front 9J x 19 EH2 IS 31 cast aluminium 7.5J x 18 light-alloy
            Wheels Rear 10J x 19 EH2 IS 25 cast aluminium 8.5J x 18 light-alloy
            Safety Special equipment features: Adaptive Headlights with cornering light, variable light distribution and adaptive headlight beam throw adjustment, high beam assistant, Park Distance Control, cruise control, automatic/extended emergency call Optional: Adaptive Headlights with Bending Lights, High-Beam Assistant, Park Distance Control, cruise control, Automatic/Enhanced Emergency Call
            Fuel Consumption EU
            urban (l/100km) 13.6 12.1
            extra-urban (l/100km) 7.3 6.4
            Total (l/100km) 9.6 8.5
            CO2 (g/km) 224 198
            Emission Rating EU 5 EU 5
            Price
            Germany EUR 50,500 EUR 40,100
            US approx. $ 46,000 $ 37,225
            Dat asss ❤ legacy image
              thrash
              I'm disappointed it's using the N54 honestly. It would have been nice to see an S54 powered car. 7k rev limit is weak.
              • E Offline
                E Offline
                Eurofan
                I concur. I would had loved to see the S54 used.. I dont think the engine had the efficiency they wanted. Nonetheless, the n54 is a great power plant, just a bit over used IMO. Virtually no turbo lag at all...but the TQ does fad substantially at 6-7k, I think that will be the only complaint among enthusiasts.
                What are your thoughts visually?
                I personally dont like the base trim 1er. This on the other hand is gold.
                  Car looks great, minus that front fender. What is this? HIN?
                  • Gundar1G Offline
                    Gundar1G Offline
                    Gundar1
                    I'm liking it. So there's two option's for packages? $37,225 and $46,000?
                    EVO
                    • E Offline
                      E Offline
                      Eurofan
                      No. The 135i is priced at 37k. Those numbers are just a comparison of the two. The m starts at 46ish
                      Did I hear right that you got a Evo?
                        thrash
                        i think the rear valence is a bit too busy. I think overall its a nice treatment on the base 1 series body, but I'm not a big fan of the 1 series coupe rear treatment to begin with.
                        I think it's entirely the wrong car though. the 128i base price is $29k; at 46k this thing is about a maxxed out 3 series. You can get a used E60 M5 for that kind of money; you can get many 911 turbos for that kind of money... even the 964 turbo. If the idea is that this is a hot small car, there are hotter, smaller cars I'd rather have.
                        BMW is considering FWD for the next 1 series. Fuck them.
                        • Gundar1G Offline
                          Gundar1G Offline
                          Gundar1
                          Yep, I bought a 2010 evo x.
                          EVO
                          • E Offline
                            E Offline
                            Eurofan
                            No pics?!?!
                            • E Offline
                              E Offline
                              Eurofan
                              http://www.youtube.com/watch?v=AcZHafarFFs&feature=player_embedded#!
                              AMAZING video...
