  4. new turbo and extras for the cummins
17 Posts 10 Posters 3.9k Views
    squawsnatch
    well the hy35 just wasn't cutting anymore. decided to go with a holset he351ve. using Fleece Performances vgt controller to control the veins. also putting on a 4" downpipe, an ATS 3-piece manifold and magnaflow 30" muffler.
    veins closed
    veins open
    had to use and adaptor to make it fit on a t3 flange
    this is what you get when you leave zac and me alone with a bandsaw and a welder.
    also got rid of the silencer ring
      You...got rid of the silencer ring?..
      • Top EndT Offline
        Top EndT Offline
        Top End
        Sure looks like it.
        ***Top End Dragways
        ***http://www.topenddragways.com
        • beachbum_jonB Offline
          beachbum_jon
          so whens the p-pump swap gonna start? Iv been thinking about a fleece setup also lately.
          -John Adams, 1735-1826-
            squawsnatch
            no p-pump for this one..... sovp44 are good to 700+ hp.
              • funky_monkey58F Offline
                funky_monkey58
                When is it going to be done?
                  squawsnatch
                  just need to finish up the exhaust and get fleece's controller to work right
                    yawn
                      squawsnatch
                      got everything finished up.
                      just used a 4" alum 90 on the intake
                      mounted the Fleece Controller under the dash
                      mounted the eb switch and realtime boost control on the dash trim
                      also have a 64/62/vgt that should be showing up any day now
                        squawsnatch
                        look what showed up in the mail today. 64/62
                          so what is that turbo capable of? I'm not familiar with diesel turbo sizing. also it looks like it is Extended tip? Is that a holset wheel, if so have they always had ett wheels or is this new?
                            squawsnatch
                            700hp on a 64mm is attainable with reasonable egt's. but that would be done on a 64/71/14. not sure what this will be capable of since its the only one made. im testing it with the stand alone vgt controller for a shop in WA. the compressor wheel is a borg warner wheel. they took a stock he351ve which is a 60/60/vgt and had the housings machined for the bigger wheels which are 64/62. not usre if you are familiar with how diesels label turbos but they use the compressor inducer and the exhaust exducer and then the housing size in cm.
                              squawsnatch
                              here is a vid, engine held at 1500rpm
                              http://youtu.be/ttnQE98IXE4
                                nice there guy...
                                little help
                                http://www.youtube.com/watch?v=ttnQE98IXE4
                                  thats pretty cool, now if they start making that in a 70+mm GTS.....
                                    beachbum_jon
                                    They do make larger vgt turbos, like off of the ISX. Although I am not sure if you can control them with the fleece controller or not, I dont see why it wouldnt work.
