  4. Overheating Jeep Cheroke
7 Posts 6 Posters 979 Views
    adrenalinejunkie002
    I'm working on a 94' Jeep Cheroke with a 4.0L that has an overheating problem and I'm running out of ideas to fixt it. I've replaced the water pump, tried a cooler thermostat, flushed the radiator, checked air flow to the radiator and replaced the temp. sensor and now I'm out of ideas. Anyone have any suggestions?
      head gasket.
        Replace the: Car, jk
        What does the exhaust look/smell like. If it has a blue/white tint to it and smells sort of sweet, its definitly coolant, and would be more than likely a headgasket.
        • RaiderR Offline
          RaiderR Offline
          Raider
          4L's heads have been cracked in the shop...R&R the head and send it out to check for cracks and to see if warped
          POWERD BY
            open a command prompt.
            format 😄
            • ticklemedalyT Offline
              ticklemedaly
              what everyone else said, headgasket, make sure to have it checked for cracks. I did one the beginning of may, and it was a pain to do, but took care of the problem.
              XBL G-tag: TickleMeDaly83
              • RaiderR Offline
                RaiderR Offline
                Raider
                if you remove the head leave the intake and exhaust manifold on...have someone help you..will be heavy as hell but thats the best way to remove the head
                POWERD BY
