  3. Run Your Mouth
  4. Fuck you Microsoft
Fuck you Microsoft
14 Posts 6 Posters 1.1k Views
    Microsoft, in their infinite wisdom, decided to make it so that you MUST use a floppy drive to load RAID/SCSI/SATA drivers before you can install Windows XP. A USB floppy drive won't work either.
    I have a floppy drive, but I don't have a frickin cable for it. 😞 Who wants to bring a floppy cable to b-dubs tomorrow?
      i might have an extra one laying around....you can have it. Unfortunatley I will be out of town this weekend though....
        You should give it to Jason tomorrow...
          A floppy throught the USB wont work? when i redid my old laptop that worked fine.
            For whatever reason its not working. It could be a shitty external floppy too.
            • Sweet-WRX-LovinS Offline
              Sweet-WRX-Lovin
              WTF? That is gayness. Won't let you download and install or download to a cd or something and install?
              One time...
                Nope, I could slipstream the drivers into the XP cd, but thats a helluva headache to do.
                Microsoft really dropped the ball on that one.
                  I'll pick up my floppy drive tommarow if I still have it and let you barrow it
                  • 9 Offline
                    9 Offline
                    911LUV
                    ...did you already toast the drive? And do you have an available computer?
                    If both no...there is a way around it....assuming if and only if...you can get access to the files needed for your SATA/Raid/SCSI card (assuming onboard, if so they came with your mobo)...
                    I wont even go into it unless you answer those questions - if you have another computer, with a CDRW - and have...an hour or two tonight to hammer down. Then I will post a detailed explanation on how to do it....I ran into a lot of issues loading up SBS2k3 on some stupid HP Proliant Servers awhile ago and did not have a floppy drive (fortunately now, there boards have a bootable USB support)
                      Cool. I really just need the cable though.
                        I just really don't feel like going through the process of slipstreaming the drivers cause I'm a lazy ass. 😄 The floppy drive should still be good as I can read the files from my laptop (its an external floppy). I think that the problem is that my mobo doesn't much care for external floppies or something like that. I want to try my internal drive, but I just don't have a cable for it.
                          mine is all one. was used as the primary floppy for my old laptop but was external.
                            You installed the OS improperly on the HP then. Rule #1 w/ an HP is to start w/ their Smart Start CD and go from there. Conveniently loads in every driver for the system as well as all HP management agents. Easy as fuck.
                            • 9 Offline
                              9 Offline
                              911LUV
                              Thanks for the tip....Yah I tend to chuck whatever they send me - so anyways - one of the new blades we just got...took my jump drive right off the bat, so that was nice. But I will keep that in mind thanks.
