  3. ICE and Detailing
  4. Shady or not?
Shady or not?
26 Posts 11 Posters 5.4k Views
    pt_pimp
    I have a question for everyone.
    My buddy went to Site On Sound the other day and wanted to buy some 4 gauge power wire, but didn't want to spend the $3 per foot for whatever power wire they sell there, Stinger I think. Thats all he needed though. He already had the good Monster Cable RCA's and the remote turn on. So they told him to just go buy the 4 gauge welding power cable from MAC's hardware, cause they use it all the time. :icon_scratch:
    I know the difference between power cables and why you pay more for the good stuff and less for the stuff at Wal-Mart. And the fact that welding power cable is NOT made for car audio at all because its plastic on the outside is stiff & can crack easily in cold temperatures or from old age. It also has fewer strands that are larger then power cable made for car audio. Which can cause them to break when they are tucked under your carpet & around your seats and what not.
    Now does this sound shady? Or even pathetic? What would you do if you found out they used that in your car? Or don't you even go to Site On Sound? Or don't you think it matters?
    '01 PT Cruiser - Black
    '67 Chevy P/U - Needs lots-o-work
    • black2gB Offline
      black2gB Offline
      black2g
      sounds bad. And why would they want to give Macs the bussiness. doen't sound like a good salesperson.
      1995 Eagle Talon
      2000 Doge Neon
      1974 Porsche 914
        HAHA use the welders wire. if its decent stuff it will be fine. its not going to crack macs uses rubber insulation on the welders wire. the strands are the standard size. its just cheap...like 19 cents a foot cheap. i used it once and it doesnt make a differance. unless you have some crazy super sonic sonar bat hearing and you can hear power wire feedback?
          Sorry to come off like an ass. But, if he's too cheap to spend a little bit and buy some decent power cable..... I would hate to see what the rest of the system is like. LOL J/K. Actually if it's just power cable your after, then go to walmart and buy their amp kit with power wire and just throw away their junk RCA's that are in there. The power wire is just fine in those kits. I believe they are made by Scosche if I'm not mistaken.
          • killer69penguinK Offline
            killer69penguin
            agreed with the walmart kit, there really acctually decent jsut because you buy it at walmart dosent mean its crap
            1993 3000GT VR4
              yep wes is right....everything in the wal-mart kits are decent besides the rca's they like to burn up 🙂
                Wire is wire n00bs. As long as you size it correctly, make good connections and use it correctly there isn't a problem.
                • capitljC Offline
                  capitljC Offline
                  capitlj
                  No thats not really true CMK. Most car audio cables have smaller strands of copper because electricity doesnt travel in the cable it actually travels on the cable. More strands = more surface area = less resistance = MORE POWER.
                  > Mitch Hedberg wrote:
                  2004 Impala LS 3.8
                    el oh el
                    Like I said, wire is wire. Larger size = more copper = less resistance You still cannot get around the fact that you need to size your wire correctly. I could wire my speakers with a #12 romex if I wanted and it would be the same as using fancy ass expensive wire from best buy.
                      This is true of signal wires, but DC travels through the cable, strand counts make zero difference. They are correct in recommending welding cable if you want to save a few dollars, the big difference will be in the flexibility of such cable. I have used welding cable 1/0 gauge and 2/0 and 3/0 on a number of competition systems, and will continue to do so in the future, including my own vehicle.....and I buy at cost w/ Stinger, Tsunami, Scosche, Etc...Think about this, the "ground wire" that connects your amp to your batter (aka chassis) is not stranded, and it works fine in 99% of all applications.
                      CMK hit it on the friggen head, wire is wire. I'll go on record saying the only major advantage of higher end RCA cables and such is in the connectors themselves, the shielding on RCA cables does almost nothing to prevent noise from being picked up (the exception being in twisted-pair cables which have some inherent noise cancelling capabilities in their design.) Proper wire routing, proper grounding, and proper size wire are the essentials to a clean signal. Period.
                        pt_pimp
                        Thank you for your guys input!
                        Couple comments though. Ya, the system that he is installing isnt the best & he is going for the cheapest route possible, like many of us do. We try to find the cheapest price for everything we buy (comparison shopping). Not a big deal.
                        But, the welder power cable I saw was not at all the same as car audio power cable. It had 3 separate cables inside the plastic with larger strands then normal in each cable.
                        Either way, shouldn't you use car audio power cable for an install (the right tool for the job) instead of welder power cable (the wrong tool for the job)? Maybe this is just an opinion? Because I don't believe that "wire is wire," Moderator. Let me show you a picture. These two wires are both 4 gauge. The one on the right is a respectable brand name 4 gauge and the one on the left is some cheap crap. I took this picture to show people to be careful of what they buy. Yes, if you size your wire correctly then you will be ok, but shouldn't you stay within the same category of wire? I could buy 0/1 gauge of the stuff on the left and it would be the same as the stuff on the right.....
                        ![legacy image](http://www.proficientautocare.com/pics/cable size.jpg)
                          Sorry, I should have clarified what I meant by that more....I meant if the actual wire size is the same (not what is printed on the jacket, the actual strands) in two given wires they will work the same regardless of what brand they are and the strand count. Remember, not everyone uses the same standards to gauge their wire. AWG (American Wire Gauge) is the standard that should be used and company "A" should have the same size 4 awg wire as company "B" does.
                          As for the cable that you saw w/ 3 conductors, that is NOT welding cable, sounds more like industrial extension cord cable. The stuff I've used has a thick jacket and a single group of strands comprising its conductor (not three seperately insulated sets.) I'm not sure if MAC sells welding cable or not, I've always bought it from welding supply stores.
                            Oh, and if you really want to buy 4 awg power cable from a "car stereo manufacturer" let me know and i will price up what it will cost for you to buy from me.
                              http://forum.realmofexcursion.com/showthread.php?t=23207
                              Some of the most diehard car audio fanatics frequent this forum. They tend to agree with me.
                                QFMFT
                                  pt_pimp
                                  Very interesting CMK. I read the thread and all the replies. I guess I'll go over to Mac's and look at the specific wire he was referring to...
                                  In most cases, like you said. Wire is wire. So for the average customer/consumer, it really doesnt matter as far as which wire is better.... just compare sizes! haha and watch out for the brand "A" on the left that tries to screw you over...
                                  So, it sounds like you own a shop... Do you use the welding wire for your average daily amp installs? And tell customers you do so? If so, what do they say?
                                  • Sweet-WRX-LovinS Offline
                                    Sweet-WRX-Lovin
                                    4 gauge welding cable can lead us to a better tomorrow.
                                    Used it in the past, will use it in the future also. The extra money per foot is for the fancy casing.
                                    One time...
                                      Are you asking me?
                                        I think you meant to refer to me. Yes, I own a shop (Trafik Jamz...part of Boost Innovations 3130 Fiechtner Drive Unit B), and no I don't use it for most of my customers installs, only those that require ridiculous amounts of current to be passed. Unlike most audio shops, I'm not trying to quadruple my money on wire/cable. I am out to make money, but not rape my customers in the process. Usually it makes sense for me to buy the "amp kits" w/ RCA/Power/Remote Turn On/Speaker cable already in them. It saves me time of having to hunt down each of those things individually, and it allows me to make a few bucks in the process (that is why I'm in business after all.) On the rare occassions that I do use welding cable, I charge nothing extra for it, explain why I'm using it, etc... Most people could not care less what is used for wire so long as it works properly and is the proper awg wire....and if you can't identify welding cable vs "power cable" just by popping your hood open or looking at your amp, you need glasses. So I'm fairly sure SoS tells their customers ahead of time as well.
                                          pt_pimp
                                          Ya, sorry, I was referring to tjamz. I thought I had heard of Traffic Jamz before, at the last Radio & TV Inc. convention, right? When Fishman was there....
                                          That's all good to know, thank you! I dont know how SoS presents the use of the welding power cable for regular installs or otherwise, but you sound like you do it respectably!
