  4. aem ems
aem ems
19 Posts 7 Posters 1.9k Views
    91nbtsi;279075 wrote:
    Just call AEM and see what they have to say. I have never had that error. Sounds like it might be a hardware issue.
    I found a bunch of instances of not being able to connect on the forums and most of them were solved with the EPROM chip not being seated well enough.
    Mitch said something about you having to downgrade the firmware to get it to work before? It is on old firmware v1.11, but came with v1.03. I downloaded the newest version of AEMPro, and will try to give that a shot today. Then see what AEM has to say.
      How are you going to downgrade the firmware if you can't connect via serial? 🙂
        EPROM burner. Obviously thats last resort, after speaking with AEM. I don't think he even has a map saved anymore.
          Sucks, what happened that started this? You just connected and got the error out of the blue? I was upgrading the firmware a few years ago with a USB adapter that went fubar and wasted the chip. AEM is good about sending out replacement chips quickly.
          • 91nbtsi9 Offline
            91nbtsi9 Offline
            I am pretty sure if it is running at all, there is still a cal on it. Not sure on the connectivity issue. Good luck, Mitch.
              Right, but if we have to hardflash the chip without being able to connect, won't that delete the cal on the PROM?
                i would bet the last time i had it connected was two years minimum. if that counts as out of the blue then yup ha.
                not only am i worried about having to buy another one but i dont have a backup cal. yea. weak. means i cant even start it with a new one.
                edit/ you asshats wrote all that before i finished two sentences?
                  Problem solved. Upgraded AEMPro and it worked on the first try.
                  • 91nbtsi9 Offline
                    91nbtsi9 Offline
                    Ha. Mitch, I thought you tried 3 different installs of AEMPro? Glad you got it working!
                      yea i was swearing up and down i had to use an older version, turned out the latest one works.. but now im hearing that switching to the newer version screws with a few things...
                        That's only happening when they update the firmware from 1.11 to 1.19. It's something in the cal conversion I think. Just don't update the firmware until you're on the dyno ready to tune?
