  4. well call it a junk yard build i guess
22 Posts 11 Posters 1.5k Views
  • 95_gsr_swap9 Offline
    95_gsr_swap
    ok so tonight i was thinking and i know that many people have done a honda build using a dsm turbo..... so in the idea that i need to save and my gsr build can go a lil cheap to make sure that i get my corolla done when i get home i was thinking about building my gsr and instead of going all out right away i was wondering wut all it would take to run a dsm turbo on my gsr engine.... but i guess wut im trying to get at is so input on if this is runnable for bout a year or two and weather or not its recomended any input would be great and a possible list of wut i would need and fab would be even better
    thanks in advance for any advice i get
    92 Honda Civic VX 1.5l vtec-e - SOLD
    86 Toyota Corolla - Project
    B18C1 Boost Project Soon To Be Done Once Home - SOLD
    92 civic coupe b18b swap
    • BassplayerB Offline
      BassplayerB Offline
      Bassplayer
      English please?
      1995 GMC Sierra
      • thurmanmermanT Offline
        thurmanmerman
        Bassplayer;297021 wrote:
        English please?
        Basically asking what it takes to put x turbo on his motor.
          95_gsr_swap
          ok sry if that was hard to understand but wut im asking is can i put lets say a 1st gen eclipse/talon turbo on a b18c1 and make it work right and wut would i need from that talon/eclipse to make it all work
          sry for the confusion
            Trafik Jamz
            proper engine management, fueling, turbo manifold, turbo, wastegate, FPR, BOV, Intercooler, wastegate, dumptube, etc, etc, etc....
            701.541.3484
              Not even necessarily a different FPR even.
                Writing legible paragraphs is one of the best ways to start, from there you will want a bigger turbo, and everything else that goes along with turboing a honda (manifold/dp/wg/injectors/bov/oil lines/fmic/piping/fuel pump/engine management).
                • ihaveaidsI Offline
                  ihaveaidsI Offline
                  ihaveaids
                  I refuse to read this block of words.
                  • blackcherryTSiB Offline
                    blackcherryTSi
                    not as much as youd think... i put a 16g on my built d16 this summer... pm me for more specific questions you want answered
                    1995 Honda Civic
                    • D S ohMD Offline
                      D S ohMD Offline
                      D S ohM
                      You plan on actually showing up to buy the injectors and resistor box this time around? Maybe the third time's a charm...doubt it.
                      I wanna go fast!
                        95_gsr_swap
                        hit me up when im home in august i will be needing more than that if u have it but pm me and ill get a list together for ya to see if u have it
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          I'll end up having most of what you need...as long as they are dsm parts. PM me the list.
                          I wanna go fast!
                            youll probably want a little bigger turbo than that. a 14b is going to choke up a gsr in the high Rs. just do it right and dont buy shitty parts
                              95_gsr_swap
                              im looking at doing the 16g i think that should be enough and im atcually looking a getting one brad new but if anyone thinks that wont be enough let me know im not looking for crazy fast at the moment maybe 10 to 15psi but any recomendations will be taken for the build need the advise
                                95_gsr_swap
                                ok so i know that i need to upgrade my map sensor to make it past 10psi and i know that the gm 3 bar map sensor is one that alot of people use but the i was told i need to have a chipped or modified ecu to recognize the voltage and i was wondering where to go or wut is recomended for this any advise would be great thanks
                                  you'll need a chipped ecu anyways, unless u dont plan on tuning anything...
                                    95_gsr_swap
                                    i know that i need a chipped ecu and i do plan on tuning, but i was wondering what the recomended brand would be or wut choices i have for this :icon_scratch:
                                      blackcherryTSi
                                      iirc, bring your ecu and 75$ to Handcommand in the cities and he will give you a socketed ecu with a pretty powdercoated cover
                                      1995 Honda Civic
                                        95_gsr_swap
                                        ok brian expect to make a trip with me when i get home cuz ill get fucking lost and it will make for a nice little trip
                                          blackcherryTSi
                                          ..... creepy.... lol jk
                                          1995 Honda Civic
