  4. Engines out, now i got a problem!
30 Posts 11 Posters 1.9k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    SO last night after work i came home and pulled my motor, neighbors arent too happy but whatever. Got it out around 1 - 2 am, Loaded it into my bros truck at 2am. Started to work on it at 9 - 10 pm last night so i got it out in quite a short while for it being my first honda motor ive pulled.
    Now the problem is that the drivers side axle is stuck in the tranny. I tried everything to get it out, prying got no where except for taking a very small chunk out of the tranny. How the hell can i get this out?
    Also the pin for the shift linkage wont come out either so i had to pull the entire linkage from the car instead of just undoing it from the tranny. How do i get this out?
    Other than those 2 problems it came out just fine. those 2 things are what actually kept the engine in longer seeing how i was working on those for about an hour to an hour and a half.
    also i did this by myself because no one came over and helped. But i guess it was a school night.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
    • ticklemedalyT Offline
      ticklemedaly
      As for the axle, you just need to keep on prying, usually, get two pry bars in there. with the linkages, youll need a pin punch small enough to get in the hole, and punch it out. Thats all you can do.
      Ryan
      XBL G-tag: TickleMeDaly83
        harwood39H Offline
        harwood39
        well i will be prying at it tomorrow
        Fargo, ND 58103
        701-429-3686
        • C Offline
          C Offline
          civ93
          o holden, think, we get to do this to my car in a month or two
          1992 Civic Cx - soon to be ls swapped
            harwood39H Offline
            harwood39
            but your axle wont be stuck in the tranny, haha
            Fargo, ND 58103
            701-429-3686
            • C Offline
              C Offline
              civ93
              ya cause it has a new axle
                harwood39H Offline
                harwood39
                Too bad it will be alot colder out tho. god thats going to suck. we need a shop we can do shit in.
                Fargo, ND 58103
                701-429-3686
                  aliengotpsi
                  so what are you gonna do with the engine? dont tell me your gonna build it back to stock? if so why? it would be cheaper and easyer to find a replacement one
                  Kevin Smith
                  Straightlinedetailing.com
                    i think harwood should do a mild n/a build...cheap to do
                      harwood39H Offline
                      harwood39
                      torbs, you know thats what i am doing, and i am going to take your advice on the P29 pistons.
                      Fargo, ND 58103
                      701-429-3686
                        harwood39H Offline
                        harwood39
                        i owuld never build it back to stock. That would be pointless. But i need to get this done ASAP cause the tranny took a dump in the taurus.
                        Fargo, ND 58103
                        701-429-3686
                          p29's, cam, springs/retainers, and MOST of all, tuning...and boom, like 160whp n/a (has been on a dyno making that with those things)...also, as far as tuning goes...see if you can convert your car to run e85...105 octane = advanced timing correct??? yes, mpg will go down, but i dont think it outweighs the price of e85 and the power that can potentially be gained.
                            Wow, oh wow.... Do some more research buddy! First word of advice quit reading forums all the time trying to get smart.
                              i know that there's been the debate bout this like 7891230 times...what am i missing exactly?...ive researched this a bunch and there's a bunch of mixed reactions. i think what i need to see is a dyno of the same car running say 92 oct. then running e85 and see the difference...that's one thing that i cant seem to find on any forums that i look at as far as hard evidence goes...basically, im just going by what other ppl say on other forums...i guess i should look and try to find the negative side...?
                                harwood39H Offline
                                harwood39
                                I am NOT going to be running e85. Im not going to go through all that extra work and also i am limited on my funds here. Thats why im doind cam, springs, retainers, p29's, ITB's, Billet rods, race bearings, Port and Polish head, 3-way Vavle job, cometic head gasket, arp head studs, and an exedy stage 2 clutch. A couple minor other things fuel wise but thats all, and an MSD ignition.
                                Also dont forget lots of tuning time next summer.
                                Fargo, ND 58103
                                701-429-3686
                                  What the hell are race bearings???
                                  • darkelvisD Offline
                                    darkelvisD Offline
                                    darkelvis
                                    Good luck getting your piston/rod combo to work. Cometic head gasket=overpriced junk. And yea, what are race bearings?
                                      why are cometic head gaskets junk?
                                        darkelvisD Offline
                                        darkelvis
                                        A cometic head gasket for a honda is essentially the same as the OEM one, except for the price. Plus unless he sleeves or fills the block, or runs a block guard (which I personally wouldn't do) honda sleeves have a tendency of shifting which causes head gaskets to blow.
                                        Just not worth it in my opinion. I'd just run OEM gaskets. 🙂
                                          he's limited on funds, so he's only gonna get "cam, springs, retainers, p29's, ITB's, Billet rods, race bearings, Port and Polish head, 3-way Vavle job, cometic head gasket, arp head studs, and an exedy stage 2 clutch".............and for some reason, even if e85 was thought about, which it isnt...all you'd need is to make your fuel system corrosive free and get some bigger injectors...as in, stainless steal fuel lines (replace any rubber or corrosive prone materials in the fuel system), injectors about 2x the normal size give or take, and a good tuning device...that doesnt sound like much money to me compared to the rest of the build...and hell harwood, even if you only get 15-20mpg with it, you'll be paying 60 cents less/ gallon and getting the benefits of 100+ octane...so to me it seems like a no brainer...thats just me tho...anybody else have any thoughts on this or know somebody that has tried it out?
