  3. Run Your Mouth
  4. Tires Plus rant
Tires Plus rant
26 Posts 11 Posters 2.8k Views
    seanjohn
    So I take in my freshly restored late 80's model Volk Racing Grup C wheels to get my tires mounted and balanced....when I come back they are all finished....except ONE. The dude working there proceeds to tell me that I have a "bad valve-stem"....they are metal, how the hell can they go bad I ask. He proceeds to show my my valve stem completely sheered in half....yeah, I'm sure THAT was just the valve stem going bad...it is my understanding the metal will split itself it half when it gets old. Now I am having a HELL of a time finding a valve stem that will fit the wheel....dude didn't even apologize or admit to it being their fault. I hate shops. end rant
    • sitn2loS Offline
      sitn2loS Offline
      sitn2lo
      damn that sucks
      Yukon Denali on 22's
        What is up wit the tire places? there fucking up everything it is insaine.....
          Valve stems do go bad. Even metal ones. I am by no means sticking up for them either. I wasn't there to witness it. I am merely stating a point. It's pretty tough for someone to fuck up a valve stem when mounting a tire because you never touch the stem in the processs. The only time a person comes in contact with a stem is if you are going to remove it. Sorry to hear about your misfortune and good luck. At least it's just a stem and not the entire wheel like in Jim's situation.
          • ticklemedalyT Offline
            ticklemedaly
            Exactly. That sucks about your wheel and all, but you really should check the "tech specs" on things before going around and neg rep other people/places. Ive been working on cars for years, dealing with tires too for years and yet have I ever "tore" the valve stem installing the tire. You should have brought NEW valve stems in with the tires and rims for them to install them. They are just a few pennies on the dollar and are a hell of a insurance deal against leaks later, which also could lead to a tire blow out. Valve stems are extremely strong, and like wes said, you usually only damage it whle removing it or old age. Goodluck on your deal.
            Ry
            XBL G-tag: TickleMeDaly83
              So I did a little homework for you and just like with a set of JDM Enkeis I had, your volk wheels require a special valve stem. (thats what you get for wanting exclusivity). It is something you should replace whenever you change tires just because of this reason. You can get them here amongst a few other places.
              http://www.daliracing.com/v666-5/catalog/index_browse_part.cfm?focus=812
              http://www.evasivemotorsports.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=RAYS-VS&Category_Code=ValveStems
              • XJHEADX Offline
                XJHEADX Offline
                Do you guys even know what metal valve stems are?????? The only way they do go bad is if the core fails, then you replace, rust out, or get sheared off/hit.....
                Did they hold air when you brought them in, I am assuming they did, tell them to replace it.....
                  I do know what they are and I do know how they go bad. If you think the only way they go bad is the core failing, then youd better go ask any "otr" truck driver who has had one fail on them on the freeway. Like I said, I wasn't there to witness it. It was stated that these wheel were from the 80's right? There is NO WAY that I'll ever use a valve stem from that long ago. All valve stems go bad even metal ones and even the almighty rays/volk ones are not failure proof. Remember they are either made from aluminum or brass and can split. I have seen it before. Oh by the way, I do work at a tire store as well. Just not there.
                  • XJHEADX Offline
                    XJHEADX Offline
                    How do they fail then????? Educate me...
                      O.K. Mr. Smarty go to a party. The most often cause of a "metal" stem failure is over tightening upon installation. Now you may ask "how could that happen". Well sonny sit right here and let me tell you a story. Nah jk. He did mention that they were a fresh restoration right? well, that would involve refinishing the wheels more than likey and you would definately need to remove the stem. They are not designed for repetitive removal and installation and tightening them over and over can compromise their strength hence making them "split" in THIS situation. And once again I will state that I wasn't there and I didn't witness this so what I am stating is speculation but I have seen them come through the door broken, split, cracked, and stripped. Not all of them were leaking from the core.
                      And I'm done. My fingers hurt.
                        ticklemedaly
                        Yes, they have metal, but they aren't entirely made of metal. they use metal parts to "pinch" the rubber sealing surface between the stem (metal) and wheel (metal). Kinda like washers pinching bushings for any suspension component.
                        Now, you ask how they go bad? Have you ever looked at a old 5-15 year old tire? rubber deteriorates over time due to age, use, and worst of all temperatures (hot to cold, hot to cold, cold to hot, etc etc).
                        As for them being restored, they should have been replaced. They should be replaced everytime a tire is removed. Now, ask yourself this personal question, would you reuse a condom? NO, at least I hope not. Would you use one that is 5-15 years old? NO, again, at least I hope not. Thank you very much, just like wes said, my fingers are tired and I hope you use a new rubber next time you work on your tires.
                        Ry
                        P.S. we weren't there ourselves, but from our experiences, rubber gets old and is cheap insurance to replace.
                          lol im sorry that condom reference was pretty funny
                            im confused how fingers get hurt while typing 5 sentences
                              those posts are short. You guys cannot complain about tired fingers.
                                I was playing video games at the time I was responding and not to mention, I'm a very angry driver so I use my finger(s) alot. Hence the fatigue.
                                  Kirk, The alphabet confuses you.
                                    who capitilizes the after a comma?
                                      Is that the best you can do?
                                        Your sentence structure is lacking.
                                          Look out! I didn't find anything to say that pleases you. Your lack of finding anything relevant to this thread is a testament as to why your not well liked on here. You seem to post just to start shit.
                                          Your my hero!:icon_thumleft:
