  4. cam gear adjustment?
43 Posts 11 Posters 2.6k Views
  • inittowinitI Offline
    inittowinit
    just got a adjustable cam gear 4 my 92 civic. its a 1.5 and is mostly oem. not to sure what the best degree to set it is. any help would be great. thanks
      stock
      too short
        Why would you get a cam gear for a mostly stock car??
        And yes stock would be best.
          inittowinit
          ok ok. lets put it this way. lookin to find a way to get more hp in the easyest way. im very unframiltir with imports???? any sugestions?
            cam gear with a stock motor will do jack
            • DanglerD Offline
              DanglerD Offline
              Dangler
              force feed it....
                mini me! u put a vtec head on the d15 and vollah, 30 hp.
                  inittowinit
                  well a friend of mine put a v tec head on his 92 civic and now his rings are shot. could the head be the problem?
                    I have that done on my car, d15b7 block with a d16z6 head. Just take your time and dont cut any corners and your good. If you just replace the key parts (new seals, gaskets, ect.) you will be A-OK:icon_thumright: Nice little boost of power.
                      Put a bottle on it and VOILA! 60+ hp.
                        inittowinit
                        cool. i have a chance 2 get a v tec head from a 2000 civic 1.6. i have been told it will fit but am not sure?
                          what year is your car? if you know the engine code that would be better.
                            inittowinit
                            its a 92 lx.
                              then u should be rocking a d15b7. mini me will work fine with that head! buy it up.
                                inittowinit
                                sweet! much apreciated!! for under a hundered bucks i figured i cant go wrong. still need new distributer and wire though
                                  if i were you i would look around and try to pick up a d16y8 head. They flow better. Plus that and if your looking at a 2000 head that is OBD2, and you are OBD1. y8's are OBD1. but...its your car
                                  Mini me's FTW:icon_cheers:
                                    inittowinit
                                    the head is a d16y8
                                      then buy that meng. Gonna need to convert your dizzy to OBD1 still.
                                        inittowinit
                                        that no big deal though! thanks again!
                                          Yeah, where you from. Might be able to help ya
