  4. Best way to heat a garage???
20 Posts 15 Posters 1.4k Views
  • G Offline
    G Offline
    green6767
    Well, my heated garage project didnt get fully finished this summer so I am back to manually heating it with portable unit for this winter. Its a triple car garage that is about half insulated not including the roof. I was wondering what the best way to heat this garage to have a comfortable work environment would be without using propane. This will be temporary until we get out permanent heating element hung and hooked to the gas line from the house probably in spring. The one I was using last year was kind of old and it stunk really bad like diesel fuel, so that didn't last long as sometimes it would burn my eyes. Suggestions, opinions, and personal experience all welcome.
    08 WRX Hatch
      throw some slow fans on the sealing to help keep heat in... othethan that... get a big electric heater and dont open the garage doors...
        If you are ruling out the propane and kerosene heaters, that pretty much leaves you with electric. I heat mine with electric, and it's nice because it's clean and doesn't smell/burn eyes. But if you don't leave the space heated all the time and just turn it on when you want to work, it takes quite a bit of time for a typical electric heater to get the space warmed up.
          breath really really fast!!!
          on a more serious note, i've had a really good experience with propane...doesnt stink at all...just get a REALLY big one! medium sized ones dont heat for shit...
          • G Offline
            G Offline
            green6767
            Well I have to rule out propane, due to some allergic reactions I get from the stuff. I am not going to rule out kerosene and diesel fuel as long as I can find one that doesn't stink too bad and wont burn my eyes. I thought about electric heaters, but I would only need it when I want to work. Are there any that dont take too long to heat up, and how long is "long"? How much higher will the electric bill be if I go with an electric heater?
            08 WRX Hatch
              what you can do is get a nepco to first heat up the garage initially because they kick balls when it comes to that, but they stink bad...then use a couple electric ones to keep the heat up.
                Kerosene will always stink. The more you use it the more you get used to it. Like eating anchovies. You understand that you have too vent it. Having a triple garage means you better go big.
                Kerosene is the same price as diesel fuel. I remember bitching at $1.70 a gallon. Hell its $2.80 now? unless someone knows where I can get it cheaper.
                • G Offline
                  G Offline
                  green6767
                  anybody heard of using Jet Fuel. I heard it doesn't stink as much and it costs about the same as kerosene?
                  08 WRX Hatch
                  • Turbo5OhT Offline
                    Turbo5OhT Offline
                    Turbo5Oh
                    berg sells a blower that u can get a heatig element for which would heat the room quickly and there wont be any smells, i have their catalog at work ill look at it tommorow aqain to see what its cost, ive been thinking about buying it for a few years now but im kind of a cheap ass
                    fuel heaters suck my ass and im pretty sure its not good for u
                    if i knew a farmer or something i would go with the new corn heaters, suppose to be very cheap to run but i dont know where u can by feed corn
                      Are there any small scale oil heaters?
                      • Turbo5OhT Offline
                        Turbo5OhT Offline
                        Turbo5Oh
                        not that ive came across but it would be awsome if u could find a small used oil furnace, im pretty sure it would be pretty easy to find large quanities of free used oil
                        but heres the link to the blower heater ive been thinking about
                        its blows 300 cfm and u can get a 1500 watt heater attachment so i think it would do pretty good
                        http://www.atdtools.com/Tools.html
                        then the part numbers are (blower) atd-30001 (heater) atd-30002
                        just use the item search
                        • darkelvisD Offline
                          darkelvisD Offline
                          darkelvis
                          I've decided that this year I'm just going to move my grill into my garage, that way any time I want to work on my car I'll just grill some burgers up first. 🙂 Other than that, I have a little stanley electric heater that keeps the (1 stall) garage right around 50.
                          • BookemB Offline
                            BookemB Offline
                            Bookem
                            How about a wood stove, they have some with fan attachments to move the hot air
                            Legacy GT
                            Gmc Suburban
                            Hallorann: Fargostreet?
                            Hallorann: No, I ain't.
                            • Turbo5OhT Offline
                              Turbo5OhT Offline
                              Turbo5Oh
                              wood stove and wood heaters are awsome but collecting enough wood to get u through the winter is a pain in the ass, and nearly impossible for some people
                              and the fact if ur insurance company finds out u have one ur premium will prolly double
                                burn dead babies.
                                • ColinC Offline
                                  ColinC Offline
                                  Colin
                                  Corn burner with a proper flue(sp): cheap to buy, cheap to run, smell fine, but you gotta keep corn husks somewhere...
                                  • R Offline
                                    R Offline
                                    rustychevy
                                    I agree, get a corn stove, they put out tons of heat for little money. Too bad they're kind of expensive for temporary use.
                                    • 91nbtsi9 Offline
                                      91nbtsi9 Offline
                                      http://www.cleanburn.com/cb1400.cfm
                                      I want that.
                                      • dubbsyD Offline
                                        dubbsyD Offline
                                        I've got a real small ceiling mounted electric that'll warm the 28x40 shop up to 50-55, maybe 60 depending how cold it is outside and how long I let it run. Cost something like $100 on sale at FreakFarm. However - the garage is insulated like a motherfucker so it hardly ever gets below freezing to begin with.
                                          ^ I've got a small electic unit in my all my garages. You can always do two of them if you want it warmer
